QoS on dialer 0
warren.miller
I am unable to get service-policy working on a dialer interface, config below:
class-map match-all voice_ccoip
match access-group name CLASS_1
policy-map voice_ccoip
class voice_ccoip
priority 128
class class-default
fair-queue
policy-map shape
class class-default
shape average 256000
service-policy voice_ccoip
Whenever I apply it to the dialer 0 interface I get the following error:
GTS : Not supported on this interface
I am new to QoS, anyone explain what I have done wrong?
Router is 2811 with WIC-1ADSL, 12.4 SP Services.
5 Replies 5
shane.orr
Level 4
Level 4
Someone will have to correct me if I am wrong but CBWFQ is not supported on Virtual interfaces like Dialers, - basically it tries to apply hardware queueing on a virtual interface. You can use nested policy-maps though. Here is an example of what I had to do for a connection that the provider had given me where 6 megs where for internet and 14 megs were for MPLS connection and in order to apply QoS to a sub-interface I used nested policy map but it will be the same concept for Dialers I believe.
class-map match-any VoIP-Control
match ip dscp cs3
match ip dscp af31
class-map match-any VoIP-RTP
match ip dscp ef
policy-map WAN-EDGE
class VoIP-RTP
priority 768
class VoIP-Control
bandwidth percent 5
class class-default
fair-queue
policy-map MPLS-14Meg
class class-default
shape average 14000000
service-policy WAN-EDGE
policy-map Internet-6Meg
class class-default
shape average 6000000
interface Serial1/0
description WAN/MPLS
bandwidth 20000
interface Serial1/0.1 point-to-point
bandwidth 14000
service-policy output MPLS-14Meg
interface Serial1/0.2 point-to-point
bandwidth 6000
service-policy output Internet-6Meg
paolo bevilacqua
Try applying the service-policy to the physical interface underlying the dialer interface.
Thanks for your response
I have tried entering it on to atm0/0/0, atm0/0/0.38 and on to the PVC. I get the same GTS: Not supported on this interface on 0/0/0 & 0/0/0.38, I tried it on the PVC 0/38, it goes in but does not appear in the config. I have read up on the subject and you can apply it to virtual interfaces just as long as the CBFWQ is nested and I am sure this config is.
The ATM interfaces I have are as follows:
interface ATM0/0/0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.38 point-to-point
ip nbar protocol-discovery
no ip route-cache
no ip mroute-cache
pvc 0/38
tx-ring-limit 60
encapsulation aal5mux ppp dialer
dialer pool-member 1
Which hardware is this ATM interface ?
In reality you do not need to shape first, because you are limited by the upstream speed. You can also easily configure an ubr rate and that will be you "shaping speed".
It is a WIC-1ADSL
