871-w (wireless router) compatability with 1131 AP
Oct 16th, 2007
We have a situation (new setup) where clients can associate to either the 871-w or the 1131 w/open authentication and reach Internet. Users can also roam (according to the 1131 console) to the 871-w and continue to work. Users cannot roam back to the 1131 from an association on the 871-w, although the 1131 shows them as associated, so does the 871-w and their traffic goes no where. Are these two devices compatable>?
Topology: 871-w with wireless enabled and 1131 trunked thru the 871-w's switch port.
Paolo Bevilacqua Tue, 10/16/2007 - 13:54
there is no defined standard for roaming is not so when you are marginal coverage you can find that the client doesn't associate properly.
Are you using well-separated channels?
You may need to reduce power, or configure a proper antenna so that the zone of your interest has a bigger difference is signal
strength.
Please send further questions to wireless forum where you can get better answers.
