CBWFQ-Frame-relay (Trying to implement COSoFR on MPLS)
Oct 16th, 2007
Hi Folks,
I am try to implement service-policy and getting the below error message.
I/f Serial0/1/1.100 DLCI 100 class interactive_voice_or_video requested bandwidt
h 512 (kbps), available only 28 (kbps)
Router#sh run int serial 0/1/1
Building configuration...
Current configuration : 158 bytes
interface Serial0/1/1
bandwidth 2048
no ip address
encapsulation frame-relay
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
end
Router#sh run int serial 0/1/1.100
Current configuration : 153 bytes
interface Serial0/1/1.100 point-to-point
bandwidth 2048
ip address 172.16.2.2 255.255.255.252
ip nat inside
frame-relay interface-dlci 100
end
class-map match-any interactive_voice_or_video
match access-group name interactive_voice_or_video
class-map match-any best_effort
match access-group name best_effort
policy-map parent
police 512000 64000 96000 conform-action transmit exceed-action drop
priority 512
class best_effort
shape average 1600000
policy-map set_precedence
set ip precedence 5
class best_effort
set ip precedence 0
map-class frame-relay FRMAP-MPLS
service-policy output parent
mzsrtgzr_cisco Tue, 10/16/2007 - 14:13
Hey,
although you are not using the adaptive becn\fecn operation, you should set the mincir. try to set it to the same value you are policing to.
gaurav_thapar79 Tue, 10/16/2007 - 20:50
How to change the mincir value.Please share the command reference & usage guidelines.
gaurav_thapar79 Wed, 10/17/2007 - 07:09
i am still facing issues and getting below error message.
h 512 (kbps), available only 1 (kbps)
Below changes:-
frame-relay cir in 2048
frame-relay adaptive-shaping interface-congestion 40
frame-relay cir out 2048
frame-relay mincir 1024
frame-relay holdq 1024
mzsrtgzr_cisco Thu, 10/18/2007 - 12:36
hey,
try putting "frame-relay mincir 524288" under the map-class.
The reason for this is that somehow the mincir is assumed to be the available bandwidth in policing, although it relates to shaping.
