C-350D
Oct 16th, 2007
hello, all
does anybody knows what are the main difference between C-350 and C-350D , D stands for delivery , but information is limited only virtual gateways are their more or something else ?
Donald Nash Tue, 10/16/2007 - 15:51
The differences are described in the AsyncOS User Guide, in their own chapter just for the C300D. It's chapter 18 in the v5.1 User Guide.
Briefly, the most significant is IronPort Mail Merge. It's an extension to SMTP that allows the mail-merge for an outgoing message to be done on the appliance. Rather than generating and sending potentially thousands of individualized messages on your own servers, you send one copy to the appliance along with the merge data. The appliance then does all the grunt work of generating and delivering the individualized copies of the message.
meyd45_ironport Thu, 10/18/2007 - 10:18
The D does not have the CASE/IPAS/VOF engine running, so there is more grunt for pushing out messages.
verylongbloke_i... Tue, 10/23/2007 - 13:27
The CxxxD platform also has 255 virtual gateways as opposed to 32 on the C series platform to help segregate mail flow across mutiple IP's whenused by email marketers
:D
steven_geerts Mon, 11/05/2007 - 20:30
Does anyone have some whitepaper or so how to implement the D series into your infrastructure?
We have C600's for our Day2Day mailflow, since there are several departments sending out daily mailings to large groups of recipients we consider implementing a separate mass mailing solution for that.
I have a few questions on how to do such thing:
1) is the 300D only a gateway product or is it also capable of maintaining the recipient lists, including (un)subscribe functions?
2) what is a smart way to configure such gateway, use several IP's for sending mass-mail, of keeping the number of IP's limited. What should be the arguments for (or against) one or the other?
3) If the 300D is "only" a gateway, what systems can I use for recipient-list management including unsubscribe functionality
4) tools are available to give non-technical users the possibility to create nice looking HTML mail?
All input is appreciated.
Steven
Donald Nash Mon, 11/05/2007 - 22:02
The AsyncOS User Guide has an entire chapter about the D model units, including what extra features they have. They don't have on-board list management.
Consult the AsyncOS Advanced User Guide. It has an entire section devoted to virtual gateways (which is what you're asking about here).
This is outside the scope of AsyncOS. You can use whatever software you want for these. I have no guidance for you here, since we're not doing anything like this.
