Audible alarm for DFM
Answered Question
Oct 16th, 2007
Is it possible to launch an audible alarm any time a critical alert is displayed in DFM??
Correct Answer by jreekers about 9 years 8 months ago
Hi Julio,
It is possible to run a script when an alert
comes to DFM, or when DFM generates an event.
What you need to do is to set up and run Notification Adapters. The Script Adapter
(Notifier) allows you to automatically take an action when a notification is
received. Upon receiving a notification, the Script Notifier invokes a custom
script supplied by you that performs user-defined actions. For example, you can
create a Script Notifier to send a page, using a paging service. Another Script
Notifier might invoke an audible alarm when mission critical notifications are
received.
There is file-notify options as well, where you can configure an output file where
the notifications are written.
"\CSCOpx\objects\smarts\conf\notifier\file-notify.conf"
Also please take a look at the other conf files, maybe it can be useful for you
(like script or trap notify)
At link below you can find configuration guide to help you how to setup it in the
correct way :
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_connectivity_monitor/1.0/user/guide/notification_adapt_startstop.html
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_connectivity_monitor/1.0/user/guide/notification_adapt_script.html
Please note that in the links when they mention "BASEDIR/smarts/conf/notifier directory", by default, that is:
/opt/CSCOpx/objects/smarts/conf/notifier
HTH,
-J
Overall Rating: 3 (2 ratings)
Correct Answer
jreekers Tue, 10/16/2007 - 16:22
  • Cisco Employee,
Hi Julio,
received.
correct way :
HTH,
-J
