NTP and CM4.2.3sr1
Oct 16th, 2007
  • Bronze, 100 points or more
Per docs below:
NTP:
http://www.pool.ntp.org/zone/north-america
Cisco
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008009470f.shtml
and
http://www.cisco.com/en/US/tech/tk869/tk769/technologies_white_paper09186a0080117070.shtml
I setup ntp.conf on Pub and left Sub ntp.conf pointing to Pub. Pub does sync up with NTP stratum 2 server and Event Logs confirm this.
However, the phones do not sync up and are 3 min behind.
Rob Huffman Tue, 10/16/2007 - 16:02
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anthony,
When we first did this change it took some time for the change to propogate out to the end user phones. If you reset a phone via ccmadmin it would update but some phones did not change until the next day. I beleive there is a time sync in CCM set for 2:00AM.
If you just changed this today it may take a while.
Hope this helps!
Rob
thisisshanky Tue, 10/16/2007 - 20:04
  • Purple, 4500 points or more
What phone models are in question ?
pklos Wed, 10/17/2007 - 00:34
  • Silver, 250 points or more
First of all please install sr2b patch. It's really good idea.
regards,
pk
aamercado Wed, 10/17/2007 - 19:34
I found the problem
I only have one sub whereby all my phones are registered to and NTP services was not started...so once it started, life was good
Odd as I thought the phones uses the pub to sync up and not the sub
