85x / 87x / 18xx / HWIC-1ADSL problems
Oct 16th, 2007
This thread is meant to track the issue in earlier ADSL firmware for the models above, where the circuit does not synchronize, or is unstable, or it has poor performances.
The necessary FW upgrade to fix the issue is publicly available with installation documentation from cisco:
ftp://ftp.cisco.com/pub/access/800
Newer ADLS firmware is also embedded in newer IOS. The mapping of ADSL FW to IOS is available at:
http://cisco.com/en/US/products/hw/routers/ps221/prod_bulletin0900aecd801d5c4c.html
Here below is "show dsl int" taken from a 1801 that would not sync ADSL with default FW.
If you have similar reports, please post them here.
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0002
Vendor Country: 0x0F 0xB5
Capacity Used: 37% 47%
Noise Margin: 24.5 dB 23.0 dB
Output Power: 19.0 dBm 12.5 dBm
Attenuation: 16.5 dB 9.5 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x33
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 8241 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Version: 3.0.33
Interleave Fast Interleave Fast
Speed (kbps): 2464 0 352 0
Cells: 21396 0 9562 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0Leakage Avarage BER: 0E-0 0E-0
LOM Monitoring : Disabled
