Richard Burts Tue, 10/16/2007 - 18:07
Oliver
While there are several commands that can be used to investigate the memory of the router, I believe that the easiest and best is the show version command. There is a line in the output that will tell what memory is installed on the router. On some platforms it will divide the memory showing the main memory and the I/O memory separately.
Rick
korbenda11as Tue, 10/16/2007 - 19:05
How do you interpret this:
Cisco 7206VXR (NPE-G1) processor (revision A) with 229376K/32768K bytes of memor y.
Processor board ID 30782791
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from watchdog reset
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Richard Burts Wed, 10/17/2007 - 14:36
Oliver
I would interpret this as a 7206 with 256 MB of RAM. It also has 64 MB flash card in slot 2 and 16 MB of onboard flash.
Rick
Richard Burts Thu, 10/18/2007 - 17:12
Oliver
add the 229376K for main memory and the 32768K for I/O memory from the line
and convert to MB.
Rick
