Design Question
Oct 16th, 2007
Hi all,
I have a question about designing a network. The plan is to have one HQ site with 4 branches for the start. But in the near future there will be up to 14 branches.
So what will be the best solution on a network basis, to be somehow resilient, cost effecive and some guarantee for bitrate and delay variation?
I thought that Frame-Relay would be a good choice since if I remember right it is based on ATM which has very godd QoS parameters..?
What do you think?
Thanks for your input.
Yves
Phillip Hichens Wed, 10/17/2007 - 00:46
Hi Yves
This all depends on your country and services providers operating there.
I would recommend getting a L3 MPLS VPN, this scales very well and you can get different offerings (Service Level Agreements) from your SP wrt. availability, QoS and jitter.
Phillip
bvsnarayana03 Wed, 10/17/2007 - 07:01
Keeping up with the technology, MPLS can be a good solution.
Depending on the load & upload / download factors, adsl is another option.
FR is also a gud solution depending on availability & is economical as well.
Point-to-point with hub-spoke topology is one more option. But expensive.
