BARS is not working
Oct 16th, 2007
BARS(Backup and Restore Server)is not working,in BARS admin page it says:
"A Backup or restore process is in progress
Please try again after some time"(this state is for past couple of days)
If i RESET, is it BARS will restart the backup imdtly or it will start as per the scheduled time..
Please some one help me out!!
pklos Wed, 10/17/2007 - 00:33
You should reset status. Do Backup Now! and check log if everything is ok.
regards,
PK
krishnamurthy.mh Wed, 10/17/2007 - 02:15
Thanks for your reply,
After Resetting BARS, still backup is not happenning.
It stops and says " staging the server x.x.x.x.....",
any suggestions...
