DHCPv6 and the ASA
Oct 17th, 2007
DHCPv6 has been added to the routers but what about the ASAs? There doesn't seem to be an IP helper for IPv6 so is there a way for the ASA to forward DHCPv6 requests?
duncanm Thu, 10/18/2007 - 09:46
Bumpage.
There must be a way to forward DHCPv6 requests.
johnd2310 Fri, 10/19/2007 - 17:10
  • Silver, 250 points or more
I am having the same issue. It seems only the routers running 12.3, 12.4 support helper address for ipv6. Even the 6500 does not have suppoprt for this. Can Cisco comment on when ip helper for ipv6 will be added to the other platforms.
John
fsebera Wed, 10/24/2007 - 07:47
  • Bronze, 100 points or more
I have a Cisco 2651XM router and run 12.3 code. The IPv6 DHCPv3 forwarder is now called "RELAY AGENT".
I also noticed the 3750 series switches do not support the relay agent feature so anyone trying to consolidate devices - well hold on. The switch provides connectivity but you will still need a router that supports "RELAY AGENT" to forward DHCPv3 request if requestor is not on the same local lan as the provider (I.E. DHCPv3 server)
Frank
duncanm Thu, 11/08/2007 - 10:42
This tends to limit having a ASA/PIX first hop as we can't do DHCP unless we have a server on each segment or manually configure a lot of settings.
etamminga Sat, 12/04/2010 - 14:55
Cisco,
Any developments in this area? I'm running the latest and greatest on my home ASA5505 but still cannot find the dhcpv6 relay.
Any workarounds available? Multicasting with the All-DHCP-Servers group maybe? All tips are welcome!
Erik
Alexander Hartmaier Tue, 10/30/2012 - 09:29
ASA 9.0 finally supports DHCPv6 relay but still no DHCPv6 server functionality with a local pool.
