Error with RF prediction in WCS
Oct 17th, 2007
recently I've installed a Cisco WCS server.In the MAPS section I have added a map (outdoor area) and I have dragged the two access point in the map(1 RAP and one MAP) to see the heat map of the signal.The problem is that for the first 2 days it worked fine but now it give me the following error:
Error: Some of the AP's RF Prediction is not yet computed. Please go to the AP placement page and place the APs properly, specify the correct antenna and then recompute the RF prediction.
I tried to do all the suggested actions but I had no changes.
My WCS version is the 4.1.91.0 and it's working on a virtual machine (that I have restarted many times) with a trial license that expires in the next 15 days.
dennischolmes Wed, 10/17/2007 - 12:29
  • Gold, 750 points or more
Try removing both APs from the map and saving. Next, go back into the map an assign the APs. If they still do not map then I would look at the traps on the controller and make sure that the AP is fine. I would also look at performing an on demand refresh from the controller to the WCS. You can do this from the management page in WCS.
Trending Topics - Security & Network
