IPbase vs ipbasek9 IOS?
Answered Question
Oct 17th, 2007
if I have a new router, that has the ipbase image on it (as ordered unfortunately), can I just simply download the ipbasek9, or even the advipservicesk9 image and it be completely operable? As in, will I have full SSH support and all will be good?
I just did a little peaking at some 2811/3560 IOS version comparisons on the Cisco Software Advisor web page. Looks like the are now calling IP BASE the older IP BASE W/Crypto. My recollection of IP BASE includes a feature set called IP BASE W/O Crypto.
You might be in luck if IP BASE is the "bottom level" authorized IOS on a basic device purchase.
The basek9 IOS feauture set gives you more than just SSH V2 stuff. You might consider jumping on the Software Advisor and comparing the feature sets on a couple of IOS feature images
I bet they upped the "BASE" feature set to account for the ever increasing default security features required at the vast majority of customer sites.
Overall Rating: 5 (1 ratings)
dirkmelvin Wed, 10/17/2007 - 06:48
I do have a CCO login, and I have access to all the images, I just haven't updated/upgraded many routers to know if it was just that simple. I figure I would have to pay for the AdvIP stuff (which is how it should have been ordered in the first place), but does the ipbasek9, just give me the SSH ability?
Correct Answer
dirkmelvin Wed, 10/17/2007 - 07:07
Thank you for the 411. I'll hop on over there now and take a gander.
