10-17-2007 06:52 AM - last edited on 03-25-2019 03:16 PM by ciscomoderator
Hello.
How many VRF can be configure on Cisco1800 and Cisco2800 platforms?
Thank you very much.
Solved! Go to Solution.
10-23-2007 08:26 AM
Recommended positioning limits for throughput and the number of VRFs scale from 2 Mbps and 2 VRFs on the Cisco 870 Series, and up to 45 Mbps and 25 VRFs on the Cisco 3845 Integrated Services Router
http://www.cisco.com/en/US/products/ps6557/products_white_paper0900aecd8051fbdc.shtml
Narayan
10-23-2007 08:10 AM
I think it depends on the protocols your running for example OSPF Support for Unlimited Software VRFs per Provider Edge (PE) Router.
10-23-2007 08:26 AM
Narayan
10-23-2007 11:20 PM
Thank you very much!
