Mike-1985 Thu, 10/18/2007 - 00:19
There is no DeviceListX anymore above CCM 4.x You should use RISPORT (realtime information system). There are enough topics about it on this forum.
raymondcidad Fri, 11/02/2007 - 07:19
Hello msabir.
I did an AXL SOAP connection to the CCM 4.1,
Now I'm trying to connect with the CCM 5.1 and I get no response. I'm following the AXL Programming paper. I even copy the Java example, getting nothing from de CCM. No errors, no data. Nothing.
[part of the code]
//prints cero!
System.out.println("available "+in.available());
while ( (ch = in.read(bArray)) != -1 )
System.out.println("this line is never printed!");
sum += ch;
sb.append(new String(bArray, 0, ch));
[/part of the code]
The complete code is the one found in (JavaExample CCM5.1)
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
I'm using Eclipse with Java 1.5.
I read another post you did when you mention some way to use Eclipse to help with this connection.
Please, please give me a little help. Some code, papers or links may be...
I'd check the Cisco AXL Web Service in the Serviceability page and it's activated.
I need to connect to the CCM to get de list of activated phones, phonesInfo, Phone Line, etc...
Thanks a lot for your time.
RCM
msabir Fri, 11/02/2007 - 07:36
  • Bronze, 100 points or more
A number of folks are running into SOAP issues. I plan to write an article on using Eclipse/NetBeans to do SOAP query to CCM to pull phone list. If I can find some time, I will do it within next few days.
carlplazag Wed, 11/07/2007 - 00:08
Hi, I have the same problem, I use the CM 5.1
What AXL method Can I use for get the same information that appear in the devicelistx ??
carlplazag Wed, 11/07/2007 - 00:12
raymondcidad Tue, 11/20/2007 - 05:40
Hello Mr. MUHAMMAD
Can you help us with the AXL 5.x connection?
I already tried everything following the AXL 5.1 paper.
Thanks for your time.
