PIX 520 migration
Answered Question
Oct 17th, 2007
I have Pix 520(6.3(3)) and i'd like to replace it with one ASA5020 but the problem is in the old config ( Conduit ,Fixup,interfaces , VPN and...)
how can i convert the old config (6.3(3)) to the new one (7.2(2))
Correct Answer by JORGE RODRIGUEZ about 9 years 4 months ago
Hi Rafael, there is currently no config conversion tools from goint to one platform of PIX to ASA that Im aware of, if you were upgrading code 6.3 to 7.x on same box the conversion would happened in the upgrade process but not in your case. Is your config a very extensive config on the 520?
I would suggest though to go over this link to reference depricated features that PIX uses and have either been replaced or removed on versions 7.x, for example condult has been depricated and replaced by way of acls , by refering to this link you can start building config on the 5520 ASA platform based on this information.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html#wp1811886
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Wed, 10/17/2007 - 07:54
Jorge
cairnsm Wed, 11/21/2007 - 11:41
An ASA with 7.0(7) code will accept a copy and paste of 6.x configuration and convert to the 7.x format. Example:
FIXUP:
VBASA(config)# fixup protocol dns maximum-length 512
INFO: converting 'fixup protocol dns maximum-length 512' to MPF commands
VBASA(config)# fixup protocol ftp 21
INFO: converting 'fixup protocol ftp 21' to MPF commands
VBASA(config)# fixup protocol h323 h225 1720
INFO: converting 'fixup protocol h323_h225 1720' to MPF commands
VPN:
VBASA(config)# vpngroup vbvpn address-pool vb-vpn-client-pool
WARNING: the 'vpngroup' command has been deprecated, and will be converted to the corresponding tunnel-group and group-policy syntax
VBASA(config)# vpngroup vbvpn dns-server 4.2.2.2
VBASA(config)# vpngroup vbvpn split-tunnel splittunnel
HTH,
Mark
