HA for IPLC and VPN
Oct 17th, 2007
we setup one IPLC from hk to China. Also, we setup VPN from HK to China (same location). from cisco web site, it supports the HA between VPN and ethernet. pls check this link
can we config the similar HA config between IPLC and VPN? the traffic goes to IPLC first. If the IPLC down, it routes to VPN. Following is my router config. pls advice the setting. thanks
---- R1 ----
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key cisco123 address
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap local-address FastEthernet0/1
crypto map mymap 10 ipsec-isakmp
set peer
set transform-set myset
match address 101
interface FastEthernet0/1
ip address
crypto map mymap
access-list 101 permit ip
interface serial 0/0
ip address
ip route seri 0/0
