5505 ASDM and Easy VPN
I am configuring my 5505 via ASDM 6.0 on the default VLAN 1 (inside). When I configure the 5505 to connect to a VPN 3000 using Easy VPN I lose the ability to manage the 5505 via ASDM (inside). I am using the Base license. I assume this is because Easy VPN uses the HTTP server to display connection status. What is the best way to use Easy VPN and also use ASDM from the (inside) interface of the 5505?
