Feature Access Code - CCME
Oct 17th, 2007
can you help me to configure Redial Softkey
of 7912 Ip phone.
CCME version : 4.1
I have also put a config, but it doesn't work :
telephony-service
load 7912 CP7912080001SCCP051117A
max-ephones 10
max-dn 10
ip source-address 10.1.3.150 port 2000
timeouts interdigit 5
max-conferences 4 gain -6
transfer-system full-consult
fac custom redial **8
create cnf-files version-stamp Jan 01 2002 00:00:00
Rob Huffman Wed, 10/17/2007 - 09:15
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Driss,
You probably want to change 7 and 8;
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone-template template-tag
4. softkeys alerting {[Acct] [Callback] [Endcall]}
5. softkeys connected {[Acct] [Confrn] [Endcall] [Flash] [Hlog] [Hold] [Park] [Trnsfer]}
6. softkeys hold {[Newcall] [Resume]}
7. softkeys idle {[Cfwdall] [Dnd] [Gpickup] [Hlog] [Login] [Newcall] [Pickup] [Redial]}
8. softkeys seized {[Cfwdall] [Endcall] [Gpickup] [Hlog] [Pickup] [Redial]}
9. softkeys ringing {[Answer] [Dnd] [HLog]}
10. exit
11. ephone phone-tag
12. ephone-template template-tag
13. end
The third soft-key button on the Cisco Unified IP Phone 7905G and Cisco Unified IP Phone 7912G is reserved for the Message soft key. For these phones' templates, the third soft-key defaults to the Message soft key. For example, the softkeys idle Redial Dnd Pickup Login Gpickup command configuration displays, in order, the Redial, DND, Message, PickUp, Login, and GPickUp soft keys.
The NewCall soft key cannot be disabled on the Cisco Unified IP Phone 7905G or Cisco Unified IP Phone 7912G.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807dc290.html#wp1010434
Hope this helps!
Rob
dbenattou Thu, 10/18/2007 - 08:13
hi,
thanks for your response.
My need is when i press the Redial softkey, it must works.
thank you
paolo bevilacqua Thu, 10/18/2007 - 15:18
  • Hall of Fame,
    Founding Member
Can you upgrade phone to 8.0(2) and try again? Do not use 8.0(3) that has a bug in directories.
