static port redirection
Oct 17th, 2007
is there a way to specify a static that is the outside address to an inside address with a range of ports on the static. in other words regular way
static (inside,outside) tcp int 5000 5000 mask
but what if the range is 5000-5056 is there a way to include the entire range on the static.
Collin Clark Thu, 10/18/2007 - 09:06
You could NAT all ports-
static (inside,outside) interface netmask
and then use the ACL to block all ports except 5000-5056. You can't do ranges however.
HTH and please rate.
