Unity DST
Oct 17th, 2007
I am taking over an existing unity UM system. How do I know whether the WindowsServer2003-KB931836-x86-ENU.exe DST patch was applied or not. The previous engineer said they did in April. But I was not able to see it in the control panel/add or remove program. Any where else can verify it? Thanks
Overall Rating: 4 (1 ratings)
Ginger Dillon Wed, 10/17/2007 - 12:18
Hi -
1. In Add/Remove Programs, make sure you check the box Show Updates.
2. In the Windows directory should be the update log file KB931836.log and the deinstaller for the KB, usually labelled $NtUninstallKB931836$.
