Dedicated DMZ Controller vs Dedicated Port on Controller
Oct 17th, 2007
Is a dedicated controller in DMZ really required for Guest Access?
I haven't found a wealth of justification for a dedicated controller in DMZ for a location which has only 3 APs.
What is the risk level of directly attaching a port on a 4400 controller to the DMZ and configuring the Guest wireless LAN to use that port?
What would be the benefit of a dedicated 4400 in the DMZ?
srahn Thu, 10/18/2007 - 04:30
The main purpose of the DMZ anchor controller is to eliminate human error security threats and physical interconnection between internal/external. Obviously, there is always the equation of cost vs performance vs security. You will find during a security audit, the auditor will ding you for having any physical interconnection between an internal network and external or DMZ network without a firewall in between. Even if it's a layer 2 connection, you'll get dinged. If you're counting on router ACL's, then you're left open to a fat-finger problem on the ACL. Either way, the DMZ anchor controller is the best way to ensure security but obviously is a costly solution for a 3 AP deployment. Less costly than a PCI audit failure, but costly.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
