Upgrade to Unity 5.0 - Which part numbers?
Oct 17th, 2007
Can someone please help? I am trying to confirm which part numbers are required to upgrade a Unity 4.0 server with current product number of UNITYU4-50USR-E which is not covered by software upgrades.
According to the dynamic configuration tool, I have come up with:
UNITY-5.x-VUP-K9 Qty 1
UNITY5.X-SL32-VUP Qty 1
UNITY5.X-UMUSER-VUP Qty 50
Am I missing anything? Thanks!
thisisshanky Wed, 10/17/2007 - 13:48
Are you going to also do any of the following ?
a. Change integration from VM to UM ,
b. Increase Ports,
c. user license counts etc
nyciscotech Wed, 10/17/2007 - 14:45
No, the current specifications will stay the same (16 port, 50UM-U, 2TTS). Thanks
thisisshanky Wed, 10/17/2007 - 14:52
UNITY-5.X-VUP-K9 and UNITY5.X-SL32-VUP - these are top level part numbers 0$.
And you dont have smartnet (SAU) or Software essentials coverage on them ?
Get hold of a Cisco partner, get your Unity covered under smartnet support and then you get the upgrade for free. Save some bucks$$ ?
