ppp authentication chap pap callin or pap chap on my Dialer interface?
Answered Question
Oct 17th, 2007
Does it make a difference which order the authentication is in if I have both the pap and chap user name s and passwords applied to the same interface? Should I have pap first of chap first? Here is my current setup:
DSL modem --> Ethernet0
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
protocol pppoe
interface Ethernet0
no ip address
ip virtual-reassembly
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer0
ip address *.*.*.169
ip access-group 102 in
ip mtu 1492
ip inspect FIREWALL out
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp chap hostname [email protected]
ppp chap password 7 ********************
ppp pap sent-username [email protected] password 7 ******************
crypto map rdln_map
Thanks for any helps!
Correct Answer by Paolo Bevilacqua about 8 years 12 months ago
You are very welcome. Please remember to rate useful posts using the scrollbox below!
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 10/17/2007 - 15:00
No it doesn't matter. With both PAP and CHAP credentials configured, whatever the ISP uses, you have, so it's ok.
- you don't need the vpdn statements, the docs referencing that are old.
- suggest you re-enable ip route cache cef
- reconfig mtu to default of 1500 and test "ping x.x.x. df size 1500", chances are it will work
- add "ppp ipcp route default" and "ppp ipcp dns request" to remove need of configure these separately.
hope this helps, please rate post if it does!
Correct Answer
Paolo Bevilacqua Wed, 10/17/2007 - 15:49
