Error during VPN Client installation for Vista
Oct 17th, 2007
On a clean installation of Vista Pro, when i start the VPN client V5.0 installation (file vpnclient-win-msi-5.0.01.0600-k9.exe) i receive an "Error applying transforms. Verify that the specified transform paths are valid" error message, and the installation stop.
Please, help me.
amritpatek Tue, 10/23/2007 - 14:47
You could be hitting cisco bug CSCeh63357. For a workaround you can install the vpn client on some other OS, like win XP, or you can use the install shield installer instead of msi installer (install shield installer is not supported on win vista).
emorgan Mon, 12/17/2007 - 09:55
Had a similar problem on XP SP2. Make sure you start the install by clicking on the .msi and not on the .exe.
