Using VACLs to replace SPAN
Answered Question
Oct 17th, 2007
Due to the limitations in the number of SPAN sessions across all switching platforms, I am planning on using a VACL w/ the capture option to mimic a SPAN session. Below is a copy of the config that I believe will safely achieve this:
ip access-list extended span_acl
permit ip host 192.168.1.1 any
permit any ip host 192.168.1.1
ip access-list permit_all
permit ip any any
vlan access-map test
match ip address span_acl
action forward capture
match ip address permit_all
action forward
vlan filter test vlan-list 101,102
int G1/1
switchport capture allowed vlan all
switchport capture
Two questions:
1. Is this necessary or is it already implied (the config guide wasn't 100% clear)
action forward
2. In order to capture bi-directional traffic, is it necessary to configure mirror ACE entries as I have done, or is this also implied?
Thanks much! Any additional constructive input will be appreciated.
Correct Answer by Prashanth Krishnappa about 9 years 4 months ago
Yes to both your questions. It is not implied otherwise. But for 1, the syntax would be something like this
vlan access-map test 10
vlan access-map test 20
action forward
Overall Rating: 5 (1 ratings)
Correct Answer
Prashanth Krishnappa Thu, 10/18/2007 - 18:03
action forward
