EIGRP STUB in L3 Access switch.
sundar.palaniappan Wed, 10/17/2007 - 15:04
Make the access L3 switch a EIGRP stub router. This way the distribution switch doesn't query the access switch for any networks that it wouldn't have been learning from another source.
Advertise only the default route from the distribution switch - you can do this by using either distribute list to allow default route only or use 'ip summary-address eigrp' command on the distribution switch.
Sundar
