ASA5505 - two public IP NAT to one local IP
support
I'm trying to use PAT to use two public IP and map to one local IP, can anyone please help to show/correct me the access-list and nat command ?
Two public IP map to one internal IP:
access-list outside_access_in extended permit tcp any host 202.100.200.55 eq 3389
access-list outside_access_in extended permit tcp any host 202.100.200.59 eq 3389
access-list inside_nat_static_1 extended permit tcp host 192.168.0.208 eq 3389 host 202.100.200.59
access-list inside_nat_static extended permit tcp host 192.168.0.208 eq 3389 host 202.100.200.55
static (inside,outside) tcp 202.100.200.55 3389 access-list inside_nat_static
static (inside,outside) tcp 202.100.200.59 3389 access-list inside_nat_static_1
my existing config allow all internal clients use dynamic nat for outgoing:
global (outside) 1 interface
nat (inside) 1 192.168.0.0 255.255.255.0
My config doesn't quite working as expected, sometimes I just can't connect using both IPs.
EL
saro
EL,
If i understand you right, you want people to be able to connect to 2 public IPs via a port (say port 25 for this example) and you want both to forward to 1 internal server. Here is what i have done in the past and it seems to work for me:
access-list smtp1 remark MailServer1
access-list smtp1 extended permit tcp host 10.1.1.25 eq smtp any
access-list smtp2 remark MailServer2
access-list smtp2 extended permit tcp host 10.1.1.25 eq smtp any
static (Inside,Outside) tcp 1.2.3.4 smtp access-list smtp1
static (Inside,Outside) tcp 2.3.4.5 smtp access-list smtp2
The above maps the both the public IPs 1.2.3.4 and 2.3.4.5 to 10.1.1.25 on port 25. It is a bit confusing in the documentation. Let me know if this works for you. I know it seems like a strange config, but the problem is the ASA does not like to have 2 globals to 1 local unless you do it with 2 separate ACLs that point to the same local IP :) It's like a workaround type of thing.
Saro
Hi Saro,
My config is working fine now.
I may have misconfigured the static NAT before.
Thanks for your help anyway !
EL
