IP-IVR getting alarm messages
Oct 17th, 2007
Hi Good Day,
the status of my IP IVR now is OK-normal operation, but i recieving bad messages from his event viewer saying " The server was unable to allocate from the system non-paged pools because the pool was empty"
event ID: 2019
can you help me what is the cause of this?
Thank you,
Peter Bishop Thu, 10/18/2007 - 01:19
Hi Lester,
if you go to:- http://www.eventid.net and type in 2019 in the 'event ID' box there are a number of solutions suggested for this error message. Might be worth a look ot see if any of those suggestions help at all
Jeremy Janusz Mon, 06/09/2008 - 13:39
This is an old topic, but just in case you are still having a problem, what version of IVR are you on? If it is 3.5(x), then there is a bug with cdp.dll. The bug is CSCsj55090.
