How to reset Cisco Phone 7905 to factory default settings
Oct 17th, 2007
Hello from Russia!
Q: How to reset Cisco Phone 7905 to factory default settings?
Standart Passwords, such as "12345" and "cisco" don't work.
Phone configured for use static IP-adress and TFTP-server settings is disable.
nomiel Thu, 10/18/2007 - 00:10
Hi! Default password is 1234, try it first.
If it doesn't help then try to reset:
1. Press **2. And then press the Yes softkey.
or
2. Press **#. Enter admin password, if asked, and then press the Enter softkey. Select Erase Configuration and press the Yes softkey and then press the Save softkey.
b.davletshin Thu, 10/18/2007 - 00:18
Hi, nomiel!
I am understand this, but:
I'm forgot password, and can't reset to default settings this phone.
1234 and other - don't work :(
Paolo Bevilacqua Thu, 10/18/2007 - 05:41
if you have access to CCO downloads, you should try the recovery images for the 7902/05/12. In the zipfile there is documentation on how to do that.
ftp://username:password@ftp.cisco.com/cisco/voice/ip-phone/client-tools/7902_05_12_Recovery.zip
hope this helps, please rate post if it does!
Paolo Bevilacqua Thu, 10/18/2007 - 06:32
No, the 7940/60 (telecaster) reset procedures do not apply to 7902 / 05 / 12 that are based on ATA technology.
AJAZ NAWAZ Thu, 10/18/2007 - 06:52
I never said that it did apply ; )
We all could do with a bit of reading practice now and then hey...
Ajaz
AJAZ NAWAZ Thu, 10/18/2007 - 07:29
Again I'm not sure this will do it but the document is platform specific.
<http://www.cisco.com/application/pdf/en/us/guest/products/ps1851/c2001/ccmigration_09186a00801b17d3.pdf>
"Resetting the Cisco IP Phone
To reset the Cisco IP Phone, enter the following command from your web
browser:
http:///reset
where ipaddress is the IP address of the Cisco IP Phone that you are resetting."
Must be a way to do it - just don't give up!
Ajaz
