CSA: Starting ciscosec Failed
Oct 17th, 2007
Hello, all!
The problem appears when I'm trying to start cisco security agent on RedHat Linux Enterprise ES 4.
Installation successfull, but CSA doesn't starts.
I'm trying
# service ciscosec start
Starting ciscosec: [FAILED]
and there is ciscosec in /etc/init.d/ folder but there is no ciscosec in
# ntsysv window.
Could you help me? Where is the problem?
Overall Rating: 3 (1 ratings)
didyap Wed, 10/24/2007 - 05:31
  • Silver, 250 points or more
You are hitting cisco bug CSCsh79424. Download the latest version of CSA and try again. If you are upgrading from an earlier version and this is not a fresh install, then you should uninstall the previous version of CSA and then install the latest version.
asafanasjeva Wed, 10/31/2007 - 05:08
Hi! I installed 5.2-225 version of CSA, but the problem still appears, here is csalog. As you can see csa failes this time in this log, but sometimes it starts.
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5032]: CiscoSecurityAgent Starting...
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: sig 11, shutdown=0, pc=80a157e, my_process_name=/opt/CSCOcsa/bin/ciscosecd
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: si_errno = 0
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: si_addr = 0x29656e
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[00] = 0x00000033
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[01] = 0x00000000
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[02] = 0x0000007b
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[03] = 0x0000007b
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[04] = 0x0826cd5f
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[05] = 0x00000000
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[06] = 0xbfff9588
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[07] = 0xbfff9500
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[08] = 0xbfffd6a0
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[09] = 0x00000003
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[10] = 0x0826cd78
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[11] = 0x0029656e
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[12] = 0x0000000e
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[13] = 0x00000004
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[14] = 0x080a157e
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[15] = 0x00000073
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[16] = 0x00010206
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[17] = 0xbfff9500
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: reg[18] = 0x0000007b
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: Stack trace:
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x80644ef]
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /lib/tls/libpthread.so.0 [0xfa49c0]
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x80a157e]
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x80a1b9a]
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x80a17e9]
Oct 31 14:44:02 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x80ae55f]
Oct 31 14:44:03 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd [0x806478a]
Oct 31 14:44:03 msks0045 CiscoSecurityAgent[5033]: /lib/tls/libc.so.6(__libc_start_main+0xd3) [0x56ade3]
Oct 31 14:44:03 msks0045 CiscoSecurityAgent[5033]: /opt/CSCOcsa/bin/ciscosecd(dlopen+0x45) [0x804d9e1]
Oct 31 14:44:03 msks0045 CiscoSecurityAgent[5033]: End of stack trace
Oct 31 14:44:03 msks0045 CiscoSecurityAgent[5033]: CiscoSecurityAgent Restarting due to fatal error...
