MLPPP
Oct 18th, 2007
hi,
can someone post a sample configuration for combining 2 ADSL lines using (ppp multilink).
i have 2 adsl lines from the same ISP, each one negotiates diffrent IP, but i can get them to have the same ip if this is requires, and my ISP support MLPPP.
i have both PPPoA and PPPoE. (ATM interface, and Ethernet with bridged modem), i can use any.
thanks.
xbaha54321 Wed, 10/24/2007 - 05:45
i am looking for a simple mlppp on a dialer interface, someone with sample config please?
spremkumar Wed, 10/24/2007 - 22:56
Though you think off bundling and using i dont think your SP will be able to authenticate both ur user id credentials supplied by a single dialer interface which i dont think is not possible.
Instead you can think of availing maximum simultaneous session as 2 for your single user id which could help you to have 2 logical pipes open for forwarding your traffic.
This is very much possible with normal plain old isdn dialups may be you can check out this with your isp.
regds
xbaha54321 Thu, 10/25/2007 - 00:39
my ISP is giving me whatever i want!
just please help me with this config!
thanks,
spremkumar Thu, 10/25/2007 - 00:58
I intend to convey the below in my earlier post...
"Though you think off bundling and using i dont think your SP will be able to authenticate both ur user id credentials supplied by a single dialer interface, which i dont think is possible. "
regds
