NAT
ericdegboevi
hi all,
I have a router with a static NAT configure as follow: ip nat inside source static X.X.X.X Y.Y.Y.Y
I have a secon ISP conneting to the same router and want to configure a redundant static nat in case the first ISP is down the second one takes over.
How can i go about it?
ankbhasi
Hi Eric,
Try this out and update if it works
interface s0
ip address
ip nat outside
interface s1
ip address
ip nat outside
interface ethernet1
ip address
ip nat inside
ip route 0.0.0.0 0.0.0.0 s0 90
ip route 0.0.0.0 0.0.0.0 s1 100
ip nat inside source list 1 route-map ISP1-map interface s0 overload
ip nat inside source list 1 route-map ISP2-map interface s1 overload
route-map ISP11-map permit 10
match interface s0
route-map ISP12-map permit 10
match interface s1
access-list 1 permit host X.X.X.X
Ankur
*Pls rate all helpfull post
