6550 Switch 1000BastT module installation
Oct 18th, 2007
hi,
i installed one WS-X6148-GE-TX on 13th slot of a 6513 while it was powered on. After detecting the module, the "show module" shows '48 unknown FRU type (major = 0x6003, mino".
Does the swithc require a reboot, does it have any minimum IOS version requirement ?
THe SUP engine is Catalyst 6000 supervisor 2 (Active) (WS-X6K-SUP2-2GE).
thanks
ankbhasi Thu, 10/18/2007 - 02:43
  • Cisco Employee,
Hi Friend,
You need minimum 12.1(19)E1 release to support this card. Which release are you running on your sup?
Ankur
glen.grant Thu, 10/18/2007 - 03:22
  • Purple, 4500 points or more
If its running catos you need at least code version 7.6.1 to support the card.
