TACACS+ PEAP and MAC in the same AP
Oct 18th, 2007
we are having a configuration in our Access Points, which I would like to know if can create troubles, because in some AP's it works perfectly, in some others we are having issues with PEAP auth.
We have TACACS+ for the Telnet into the AP's, Mac Authentication for compatibility reasons, and are now introducing PEAP.
the aaa part looks like this:
aaa authentication login default group tacacs+ local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods group rad_mac
aaa authentication enable default group tacacs+ enable
but can we have troubles with the first line where is "default" ?
Jorge
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Thu, 10/18/2007 - 12:35
Jorge,
No, that is not going to give you any trouble unless there is any software bug.
You will bind "method list" to a specific interface. Once done, default will ignore that interface.
Please rate if helps.
~JG
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
