EIGRP Static Route Redistribution
Oct 18th, 2007
Hi, I need some advice on the default behaviour of 'redistribute static'.
Background - we have a fully routed core network with Cat 6500's. Our Exchange network is behind an ISA firewall and is split across two 6500's for resilience. One of the 6500's routes traffic to exchange via ISA with a static route which is redistributed into EIGRP and propagated to the rest of the network i.e:
ip route x.x.252.0 255.255.255.0 x.x.42.10
x.x.42.10 is the IP address of the ISA Firewall.
I need to implement resilient routing for the Exchange network, I've tried adding the static route on the second 6500 and redistributing this but this is causing a routing loop on our other routers that have connections to both of the exchange routers:
6500#sh ip route x.x.252.0
Routing entry for x.x.252.0/24
Known via "eigrp 138", distance 170, metric 3072, type external
Redistributing via eigrp 138, bgp 64750
Advertised by bgp 64750
Last update from x.x.110.3 on Vlan3, 19:43:27 ago
Routing Descriptor Blocks:
* x.x.110.3, from x.x.110.3, 19:43:27 ago, via Vlan3
Route metric is 3072, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
x.x.1.26, from x.x.1.26, 19:43:27 ago, via Vlan806
x.x.1.9, from x.x.1.9, 19:43:27 ago, via Vlan802
The first route above via Vlan3 is from an old link that we'll be taking out of service shortly and originates from the same 6500 as the second route.
The third route is the one which I think is causing the loop and comes from the second 6500 that I tried to add the static route to.
I don't understand why the third route gives a hop count of 1 when the IP Address for ISA is not active on that router?
I hope this makes sense, if not please ask and I'll try to clarify!
Any tips would be appreciated?
Overall Rating: 5 (2 ratings)
Edison Ortiz Thu, 10/18/2007 - 04:39
  • Hall of Fame,
    Founding Member
It's one hop away from the device performing the redistribution, not the destination IP.
robward Thu, 10/18/2007 - 04:42
OK, I'm lost as to why I'm getting a routing loop then. I'd have thought EIGRP would use the correct route?
Edison Ortiz Thu, 10/18/2007 - 04:49
  • Hall of Fame,
    Founding Member
Can you post a traceroute from the routers experiencing the loop ?
If both 6500s are redistributing static, the leaf routers will see two routes and should load-balance between the two 6500s.
Something is missing from your post that is causing the loop. Posting the configs will help.
robward Thu, 10/18/2007 - 05:27
The affected Routers are connected to both of the 6500's on Ten Gigabit links.
The static route is:
I have EIGRP configured with 'redistribute static'.
Traceroutes look like each 6500 is trying to send the packet back to the other but only one of them (the original 6500) is routing for the x.x.42.x network that the ISA Firewall is on:
rb-cs1#traceroute x.x.252.74
Tracing the route to imap.x.x (x.x.252.74)
1 ct-cs1-rb-cs1.x.x (x.x.1.9) 0 msec
mr-cs3-rb-cs1.x.x (x.x.1.26) 0 msec
mr-cs3.x.x (x.x.110.3) 0 msec
2 mr-cs2-ct-cs1.x.x (x.x.1.6) 0 msec * *
3 mr-cs3-mr-cs2.x.x (x.x.1.14) 0 msec * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9
For info mr-cs3 is the original 6500 that's routing for the x.x.42.x network. Rb-cs1 is the router in 'the middle' and ct-cs1 is the other router that has the static route applied.
I can post configurations if necessary but they are quite big these are heavily populated 6509's!
Edison Ortiz Thu, 10/18/2007 - 12:29
  • Hall of Fame,
    Founding Member
You can cut down the layer2 stuff.
Try this command
show run | be router
and post its output here. I suggest you sanitize it and just leave the last 2 octects on IP addresses.
robward Fri, 10/19/2007 - 00:43
Here's the mr-cs3 configuration:
router eigrp 138
redistribute static
passive-interface Vlan7
passive-interface Vlan254
passive-interface Vlan442
passive-interface Vlan520
passive-interface Vlan521
passive-interface Vlan522
network x.x.0.0
distribute-list 15 out Vlan3
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route x.x.42.112 255.255.255.240 x.x.42.98
ip route x.x.42.128 255.255.255.240 x.x.42.98
ip route x.x.42.144 255.255.255.240 x.x.42.98
ip route x.x.253.0 255.255.255.0 x.x.42.10
ip route x.x.247.128 255.255.255.128 x.x.247.2
ip flow-export destination x.x.119.223 9996
no ip http server
ip pim rp-address x.x.27.1 override
logging x.x.100.139
logging x.x.110.210
access-list 15 permit x.x.0.0 0.0.255.255
access-list 15 permit x.x.247.0 0.0.0.255
access-list 15 deny any
access-list 30 permit x.x.99.186
access-list 30 permit x.x.8.17
access-list 30 permit x.x.5.210
access-list 30 permit x.x.5.194
access-list 30 permit x.x.5.178
access-list 30 permit x.x.31.0 0.0.0.255
access-list 30 permit x.x.100.0 0.0.0.255
access-list 30 permit x.x.102.0 0.0.1.255
access-list 30 permit x.x.110.0 0.0.0.255
access-list 30 permit x.x.134.0 0.0.0.255
access-list 30 permit x.x.241.0 0.0.0.255
access-list 30 permit x.x.253.0 0.0.0.255
access-list 30 deny any
access-list 40 permit x.x.100.45
access-list 40 permit x.x.102.151
access-list 40 permit x.x.100.139
access-list 40 permit x.x.5.210
access-list 40 permit x.x.5.194
access-list 40 permit x.x.5.178
access-list 40 permit x.x.31.153
access-list 40 permit x.x.31.154
access-list 40 permit x.x.31.150
access-list 40 permit x.x.31.151
access-list 40 permit x.x.110.0 0.0.0.255
access-list 40 deny any
access-list 100 permit ip x.x.64.0 0.0.0.255 x.x.0.0 0.0.255.255
access-list 100 permit icmp x.x.64.0 0.0.0.255 x.x.0.0 0.0.255.255
access-list 102 permit ip x.x.138.0 0.0.0.255 host x.x.137.20
access-list 102 permit ip x.x.213.0 0.0.0.255 host x.x.137.20
access-list 102 permit ip x.x.137.0 0.0.0.255 host x.x.137.20
access-list 102 permit tcp any host x.x.137.20 eq domain
access-list 102 permit tcp any host x.x.137.20 eq www
access-list 102 deny ip any host x.x.137.20
access-list 102 permit ip x.x.138.0 0.0.0.255 host x.x.137.14
access-list 102 permit ip x.x.213.0 0.0.0.255 host x.x.137.14
access-list 102 permit ip x.x.137.0 0.0.0.255 host x.x.137.14
access-list 102 permit tcp any host x.x.137.14 eq 443
access-list 102 permit tcp any host x.x.137.14 eq www
access-list 102 deny ip any host x.x.137.14
access-list 102 permit ip any x.x.215.0 0.0.0.255
access-list 102 permit ip any x.x.216.0 0.0.0.255
access-list 102 permit ip any x.x.213.0 0.0.0.255
access-list 102 permit ip any x.x.137.0 0.0.0.255
access-list 130 deny tcp any any eq 135
access-list 130 deny udp any any eq 135
access-list 130 permit ip any any
access-list 1020 deny FFFFFFFF 640
access-list 1020 permit FFFFFFFF
snmp-server engineID local 000000090200000021000000
snmp-server community snmaccess RO 40
snmp-server ifindex persist
snmp-server packetsize 8192
snmp-server enable traps chassis
snmp-server enable traps module
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server host x.x.31.150 swread chassis module envmon
radius-server source-ports 1645-1646
control-plane
dial-peer cor custom
line con 0
exec-timeout 20 0
password 7 1104181D1E
login authentication CON
line vty 0 4
access-class 30 in
exec-timeout 20 0
password 7 082C4D5600
login authentication VTY
line vty 5 15
access-class 30 in
exec-timeout 20 0
login authentication VTY!
ntp clock-period 17179986
ntp update-calendar
ntp server x.x.31.3
ntp server x.x.31.2
no cns aaa enable
end
robward Fri, 10/19/2007 - 00:52
Here's the ct-cs1 configuration - the static route has been removed for now:
router eigrp 138
redistribute static
network x.x.0.0
no auto-summary
ip classless
no ip http server
logging x.x.100.139
logging x.x.110.210
access-list 15 permit x.x.93.0 0.0.0.255
access-list 15 permit x.x.245.0 0.0.0.255
access-list 15 permit x.x.246.0 0.0.0.255
access-list 15 permit x.x.0.0 0.0.63.255
access-list 15 permit x.x.247.128 0.0.0.127
access-list 101 permit ip x.x.0.0 0.0.255.255 x.x.5.224 0.0.0.15
access-list 101 permit icmp x.x.0.0 0.0.255.255 x.x.5.224 0.0.0.15
control-plane
line con 0
exec-timeout 20 0
password 7 04560A1E06
line vty 0 3
access-class 30 in
exec-timeout 20 0
password 7 09414F1110
transport input telnet
line vty 4
access-class 30 in
exec-timeout 20 0
line vty 5 15
access-class 30 in
exec-timeout 20 0
ntp clock-period 17179879
ntp update-calendar
ntp server x.x.31.3
ntp server x.x.31.2
no cns aaa enable
end
Kevin Dorrell Thu, 10/18/2007 - 04:58
  • Green, 3000 points or more
What does your BGP 64750 do? Do you have any other BGP ASs in your topology, and do they have redistribution with EIGRP? Just a thought - the BGP might be part of the equation.
Kevin Dorrell
Luxembourg
robward Thu, 10/18/2007 - 05:06
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9
WRT BGP - this advertises our address range to our ISP. We receive only a default route from them via BGP. There are no other BGP Peerings but this one.
sundar.palaniappan Thu, 10/18/2007 - 12:53
Can you clarify a couple of things.
Does mr-cs3 has this static route 'ip route x.x.252.0 255.255.255.0 x.x.42.10' in it's config?
If it does then can you get to the x.x.252.0 network from mr-cs3?
robward Fri, 10/19/2007 - 00:42
Thanks for this gents!
Yes mr-cs3 does have the static route in its configuration but I've currently removed it from ct-cs1. Things work at the moment, the problem is when I add the static route to ct-cs1 and it's redistributed via EIGRP.
robward Tue, 10/23/2007 - 07:25
Bump, still stuck on this guys anyone got any ideas?
Kevin Dorrell Tue, 10/23/2007 - 07:46
You are adding a ip route x.x.252.0 255.255.255.0 x.x.42.10 on ct-cs1. You say that "the IP address of the ISA is not active on that router". Are you sure of that? It may not have a complete path to the ISA, but does it think is has a route?
Go to ct-cs1 and do show ip route x.x.42.10. What do you have? If it thunks it has a route, then it will redistribute, regardless of real reachability.
Kevin Dorrell
Luxembourg
robward Wed, 10/24/2007 - 01:35
ct-cs1new#sh ip route x.x.42.10
Routing entry for x.x.42.0/27
Known via "eigrp 138", distance 90, metric 3328, type internal
Last update from x.x.1.6 on Vlan801, 5d19h ago
* x.x.1.10, from x.x.1.10, 5d19h ago, via Vlan802
Route metric is 3328, traffic share count is 1
Total delay is 30 microseconds, minimum bandwidth is 1000000 Kbit
Loading 1/255, Hops 2
x.x.1.6, from x.x.1.6, 5d19h ago, via Vlan801
mr-cs3 is currently routing for the x.x.42.0/27 subnet and ISA (x.x.42.10) is active on mr-cs3 at present so ct-cs1 can see two routes through the network to ISA which is what I'd expect to see.
However when I add the static route:
to ct-cs1 this is when the problem occurs, even though mr-cs3 is routing for the x.x.42.0/27 subnet.
Kevin Dorrell Wed, 10/24/2007 - 03:55
I think there is already something wrong with the route from ct-cs1 to the subnet x.x.42.0/27 and onwards to the ISA. It's just you don't know about it because nobody is actually using ct-cs1 to get to the ISA. They wouldn't use the metric 3328+ route through ct-cs1new when they could quite happily use the metric 3072 routes through the other two.
But that all changes when ct-cs1 gets a static route and starts redistributing it through EIGRP 138. Now the access routers see three equally attractive routes, and distribute the load accordingly.
In theory, any packet that arrives at ct-cs1 from your access layer should be sent to mr-cs3. But in the sh ip route x.x.42.10, it shows that ct-cs1 has two routes: a correct one to mr-cs3 and an incorrect one to mr-cs2.
So, what happens to a packet that gets sent to mr-cs2? Well, under the old conditions, mr-cs2 had only one route to x.x.42.10, and that led ultimately to mr-cs3. But with ct-cs1 in place, does mt-cs2 always lead back to mr-cs3 probably not.
You probably know the "feasible successor" rule in EIGRP. It is designed to prevent loops. It says that the neighbor is a feasible successor if its AD is less than my current metric. One question that is often asked is "what happens if it is equal?" "What happens if my meighbor is the same distance from the destination as I am? Is he a feasible successor? The answer is no, he isn't. And it seems to me that we have a very similar situation here: three routers that have the same metric to the destination (because all three are redistributing a static), but only one of which has a real route to the destination.
OK, so what is the solution? I think that either you will have to make sure that ct-cs1 and mr-cs2 always route their ISA traffic directly to mr-cs3, and never to each other, or even indirectly via another router that has multiple routes .... or, more elegantly, reduce the re-distribution metric on the one that has the real route to the ISA, namely mr-cs3.
The problem is that by having an indirect route to x.x.252.0/24, and redistibuting it with the same metric as the router that has the real route, you are telling the rest of the network that all three routers can handle the traffic equally well. Which they cannot.
Kevin Dorrell
Luxembourg
robward Wed, 10/24/2007 - 04:41
Hi Kevin, that makes sense although ct-cs1 is not directly connected to mr-cs3. The two possible routes are via mr-cs2 and rb-cs1.
The show ip route command without the network address only appears to have one entry in the routing table.
So from what you've said you think I should add a higher AD i.e. 201 to the static route on ct-cs1?
Thanks for your help by the way!
Kevin Dorrell Wed, 10/24/2007 - 04:56
I would not do it that way. The AD is only a local concept within the router, and would not affect the decisions made by the other routers.
In you routers, you are redistributing static routes into EIGRP. Each of these routes will have a seed metric. What I am surprised at is that I don't see this default-metric in the router eigrp 138 section. The documentation says that redistributed "connected" routes get a metric of 0, but it is not clear if that applies to statics.
I would try something like default-metric 1000 25 255 1 1500 in the eigrp sections of both ct-cs1 and mr-cs2. That should put them at a significant disadvantage compared to the routes from mr-cs3.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_eih.htm#wp999030
BTW, in you original posting, you said "I don't understand why the third route gives a hop count of 1 when the IP Address for ISA is not active on that router?" It is because it doesn't know whether the static route is activ, direct, or indirect. That is the hop count to the redistribution point.
Kevin Dorrell
Luxembourg
robward Wed, 10/24/2007 - 05:20
Thanks Kevin, I'll give that some thought as I'll have to assess the impact on the other networks that we'll be routing on ct-cs1.
I've done something similar with AD with backup static routes for our BGP peering by adding a default static route with an AD of 201 and redistributing this with EIGRP.
Under normal operation when our BGP peering with our ISP is in operation the BGP route with an AD of 200 is redistributed by EIGRP. If the BGP peering dissapears then the static route gets redistributed by EIGRP. This seems to work nicely.
Kevin Dorrell Wed, 10/24/2007 - 05:28
If you don't wany to touch the other redistributions, you can set the sed metric for this one only by setting a route-map:
ip access-list standard IVS
 permit x.x.254.0 0.0.0.255
route-map permit static->eigrp 10
 match ip address IVS
 set metric 1000 25 255 1 1500
route-map permit static->eigrp 20
! lets the rest of the routes through without modification of the metric
router eigrp 138
 redistribute static route-map static->eigrp
Kevin Dorrell
Luxembourg
robward Wed, 10/24/2007 - 05:32
Yes, that's the one!
Thanks I'll let you know how it goes, here's your points!
