Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927512members
1240269discussions
Community Activity
Swithc oonfig
I am using a 3750 switch and going through a Sidewinder G2 firewall. Thefirewall only has its startup config on it with and Internal IP address (.1)which will be the internal gateway. My switch has VLAN2 config of .2. I can ping from my switch to the...
L3 Switches connecting to Firewalls
Hi All,I have a topology as shown below:The Firewalls A & B are running as active/standby. I have an etherchannel configured between L3 Switch A and Switch B. The switches also have HSRP running for various VLANs. The link between Switch and Firewall...
Ranjita by Level 1
  • 12 Views
  • 0 replies
  • 1 Helpful votes
NCS-5504 credentials loss
Hi Team,By mistake i have been deleted root credentials on my NCS-5504 XR . Now i am unable to login router. Any procedure how to recover the credentials.RegardsSalman+919871873874
Renewall of Admin Certificate
I have to renew the admin certificate in a pair of ISE nodes (Prim / Sec) on Version 3.2.0.542 Patch 4. Currently both devices have the same admin cert that expires in little over 3 weeks. All the names and IPs in this thread are placeholders. I gene...
Sergio C by Level 1
  • 49 Views
  • 1 replies
C9800-CL please register this device in 58 days alarm
Hello. The following alarm is constantly occurring in the C9800-CL raised to vm. It's like an alarm related to a license, is there a solution? -----------------------------------------------------------------------------------------------------------...
CCC3 by Level 1
  • 64 Views
  • 1 replies
SSM ON-Prem TACACS+ and Clearpass
Hi,I am trying to configure TACACS+ on our SSM On-Prem server so that I am able to login on the Webinterface with my AD user. The TACACS+ configuration is done in Clearpass. And the test in the configuration window on the SSM server was successful.Bu...
Counterdoc_0-1713516283437.png Counterdoc_1-1713516355075.png Counterdoc_2-1713516408976.png
I cannot verify warranty expiration date on my 9200 switch
Hi guys,I'm trying to check the warranty expiration date of my 9200 switch, I just checked by SN on Device Coverage Checker (cisco.com) it says the warranty is covered but I cannot verify when the expiration date. How can I see when the expiration da...
yum3372 by Level 1
  • 72 Views
  • 3 replies
High Memory Utilisation 9200L
We are seeing random high memory utilisation spikes on our Cisco 9200L switches, running version 17.9.4a. We thought this might be related to the application visibility that is pushed out to them via Cisco Catalyst Centre, so we disabled application ...
CSCvb29204 - BenignCertain on IOS and IOS-XE
Hi When nessus scan, we got vulnerability info as below. Any solution can be used for this issue? A remote device is affected by an information disclosure"The IKE service running on the remote Cisco IOS device is affected byan information disclosure ...
Providing value to the parameter in yaml through CLI
Hi Team, This is the format of my yaml file: testbed:    name:    servers:    password:    custom:        version: "10.3.4" Instead of providing the value to the version manually in the yaml, I want to provide this value with the CLI I am using for e...
o1 by Cisco Employee
  • 60 Views
  • 1 replies
