Pix 515 CPU 90%-100%
Oct 18th, 2007
Out Cisco Pix 515 has been fine for months/years on the CPU since the last week. The average has always been 10%-20% until the beginning of October where it's hit 90%-100%, what steps do I need to take first?
whiteford Thu, 10/18/2007 - 07:01
Thanks for think, but I don't understand the outputs, the memory is low on the ADSL tool, see below for the CPU info:
User Access Verification
pix# show xlate count
526 in use, 2023 most used
vogate# show processes cpu-hog
pix# show processes cpu-hog
MAXHOG NUMHOG LASTHOG Process
810 43 110 Dispatch Unit
320 873 160 tmatch compile thread
1870 7 110 emweb/https
170 12764 160 snmp
pix# sh int e1
Interface Ethernet1 "inside", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address 0004.9ad0.d611, MTU 1500
IP address 192.168.10.50, subnet mask 255.255.0.0
5169231618 packets input, 746373881005 bytes, 0 no buffer
Received 4472764 broadcasts, 0 runts, 0 giants
45207 input errors, 0 CRC, 0 frame, 45207 overrun, 0 ignored, 0 abort
0 L2 decode drops
3346711203 packets output, 810671972009 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (80/269)
output queue (curr/max blocks): hardware (0/89) software (0/1)
Traffic Statistics for "inside":
5170627577 packets input, 671569112347 bytes
3346742625 packets output, 738364163374 bytes
3373483364 packets dropped
vogate#
JORGE RODRIGUEZ Thu, 10/18/2007 - 07:19
Try rulling out physical connections problems as there seem to be errors on interfaces.
" 45207 input errors, 0 CRC, 0 frame, 45207 overrun, 0 ignored, 0 abort " this could contribute to high cpu but there may be other reasons.
check physical interfaces
" show interfaces " note counters
if there are erros you many want to watch and note if counters increment or clear cunters.
e.g
pix#config t
pix(config)#clear interface
then check counters again.
if interfaces speed are hard coded to 100/full make sure what they connect to is also 100/full etc..
whiteford Thu, 10/18/2007 - 07:47
Nothing has been changed on the Pix for a long time, and it hasn't been rebooted for a few weeks. Could a reboot just be a good idea?
JORGE RODRIGUEZ Thu, 10/18/2007 - 09:09
you could try that, however, something must be causing high cpu and it is suspected it may go back to high CPU again after reboot. You may try rebooting but be prepare to investigate fruther with the link I provided to seek the cause of high cpu if it does occur again.
