Frame-Relay help needed --Connected 3 Routers
hassan_syed6
I have created a Lab where one Router is acting like a Frame switch and other two routers are connected to it. But what i see on my other routers is when i do "show frame pvc" i see "Status as Static' why am i not seeing it "ACTIVE". I cannot do " sh frame lmi" even when i configure the LMI on switch and Routers. Also i couldn't see the " sh frame map" nothing was under it. In my fRAME Switch i see in my " sh frame route" the status Static. Is this normal or any changes are needed in configuration. Kindly assisst.
Frame-Relay-Switch#
interface Serial0/0
no ip address
encapsulation frame-relay
no keepalive
clock rate 64000
frame-relay intf-type dce
frame-relay route 200 interface Serial0/1 100
frame-relay route 201 interface Serial0/1 101
interface Serial0/1
no ip address
no keepalive
clock rate 64000
frame-relay route 100 interface Serial0/0 200
frame-relay route 101 interface Serial0/0 201
Frame-Relay-Switch#sh frame-relay pvc
DLCI = 200, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE =
Serial0/0
DLCI = 201, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE =
Serial0/0
DLCI = 100, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE =
Serial0/1
DLCI = 101, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE =
Serial0/1
Frame-Relay-Switch# sh frame-relay route
Input Intf Input Dlci Output Intf Output Dlci Status
Serial0/0 200 Serial0/1 100 static
Serial0/0 201 Serial0/1 101 static
Serial0/1 100 Serial0/0 200 static
Serial0/1 101 Serial0/0 201 static
Router # 1 ( M)
interface Serial0
no ip address
no keepalive
interface Serial0.1 point-to-point
ip address 192.168.12.1 255.255.255.252
frame-relay interface-dlci 100
interface Serial0.2 point-to-point
ip address 192.168.12.5 255.255.255.252
frame-relay interface-dlci 101
Router#1 #sh frame-relay pvc
DLCI = 101, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE =
Serial0.2
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE =
Serial0.1
Router # 2----- (S)
interface Serial0
no ip address
no keepalive
ip address 192.168.12.2 255.255.255.252
frame-relay interface-dlci 200
ip address 192.168.12.6 255.255.255.252
frame-relay interface-dlci 201
Router#2 #sh frame-relay pvc
DLCI = 200, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE =
Serial0.1
DLCI = 201, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE =
Serial0.2
6 Replies 6
paolo bevilacqua
you need to configure frame-relay intf-type dce
on s0/1 on router 1 too.
Can you ping successfully between endpoints ?
Both Interfaces on the Frame switch are DCE. Yes, both routers R#1 and R#2 can ping each other fine. It's just the PVC status "Static" which is confusing me.
Hassan
Did you have the command frame-relay switching on the FR router? I presume so because the routers can see each other.
I think all the "static" means is that the DLCI is statically assigned to your point-to-point interface by the frame-relay interface-dlci. Try creating a third DLCI and don't put it on a subinterface. I think it will get assigned dynamically to the physical interface.
Kevin Dorrell
Luxembourg
Hello kevin.
Yes frame-relay switching command is there.
I have searched google to see what they say on it. What i notice is their output gives them "ACTIVE" status. But I am getting " Static" PVC's. Hmm...not sure at this time.
Well the command was missing in the config you sent :)
Sorry, which command am i missing, which is causing the PVC status to be " STATIC" rather then " ACTIVE" ..can you kindly confirm.
Hassan...
