10-18-2007 06:06 AM - edited 03-15-2019 12:01 AM
I have two phones that keep saying registration rejected. We have changed the vlan for our phones and have done some ccm upgrades.
10-18-2007 07:25 AM
Were they ever registered? if so you might be facing a cluster database replication issue.
If not then they should be added ;)
HTH, Avner.
10-18-2007 10:50 AM
Simple test.. take a phone that WONT register and plug it into a port with a Registered PHONE.. if it works them possible a VLAN issue..
We have seen this before.. Could also be a IP conflict issue in that case I have had to completely delete the phone from the CCM database and see if Auto Registration works to register that phone..
10-19-2007 12:13 PM
you get this message also if the MAC address is incorrect in CCM
10-22-2007 12:18 AM
You have ip source-address with the IP address of your CME roter, but do you use the strict-match option ? This could be your problem.
