CCM DST and ciscocm-2007-JRE-DST-Update.1-0-1.exe
Oct 18th, 2007
tryiug to verify whether customer has patched JRE(java runtime engine) in the past according to this link
I even can not find this in cco , and how do I verify whether customer has applied or not? My customers has 3.35/4.13/4.23 three platforms. Thanks
waynetall Thu, 10/18/2007 - 08:46
Hi there,
The download link is here, the file now is in archive:
Check the log to see if the patch was applied:
c:\program files\common files\cisco\logs\Cisco Unified Communications JRE DST Updater xxxx-xx-xx xx.xx.log, accessible via Start/Cisco Install Logs in the ccmpatch folder.
Hope this helps.
