WAE - Print Services
vipul.vajshi
Can we integrate print services into Windows AD, so when a user wants to select a printer to install it can be be found in AD, rather then having to map the edge WAE from the desktop?
Vip
Zach Seils
Level 7
Level 7
Vipul,
You will need to manually add the print queue object to AD.
Zach
Hi Zach,
So we don't need to do any configuration to the WAE, just AD side of things?
Vip
Vip,
In terms of getting the print queue object into AD, there is nothing to do on the WAE. You would, of course, have to configure Print Services on the WAE, but that is unrelated to the object being added to AD.
Zach
Hi Zach,
Thanks very much, they have added it in AD and they can see the printers!
Legend!
Vip
