AP Naming in Lwapp
Oct 18th, 2007
I am getting ready to do a conversion from Autonomous/WLSM/WLSE to Lwapp and would like to know if there is a way to load the names of the AP's in the Lwapp controller or WCS. Currently I use the auto config CSV infomation in the WLSE to config the settings on my AP's but I don't see a way to load this information in the Lwapp devices. I see I can change the MAC adress name one at time but I would like to load them all. I have about 600 AP's.
Dmitry Halavin Fri, 10/19/2007 - 06:30
No, there is no way to do this currently.
The easiest way to do this right now is to do it per controller, and once you know the naming pattern of the APs (ie, AP.MAC_ADDRESS) you can use a text editor to create a batch script if you have the names you want to use.
jcosgrove Fri, 10/19/2007 - 06:55
I think cisco needs to improve the administration tools available in the Lwapp line. This is supposed to be designed for larger networks but you still need to admin each device independently. They need a device import function to import device names and configs similar to the .csv files on the WLSE.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
