Crossover between 2 Pixen
Oct 18th, 2007
I have a second Pix that I'd like to directly connecting on one interface to the existing Pix (both 525's).
Interestingly, the existing Pix's port goes up/up when the crossover is attached, while the new Pix goes up/down. Same subnet, same mask, no gateway, hardset speed/duplex... nothing jumps out.
The only difference between their respective config's is Int Name (not quite the same) and Security level.
Anyone ever come across an up/up and up/down situation on a crossover connection?
Mike
