TAPS on CM5.1 using IPCC 4.5
martin.wawryka Thu, 10/18/2007 - 12:46
Hi Joel,
Here you go:
Note: For Cisco Unified Contact Center Express version 4.0(x) and later, TAPS installs the TAPS AAR.aar file on the server, not the TAPS.aef file as in the earlier versions. In other words, TAPS.aef is now a part of the .aar file.
Complete these steps in order to resolve the issue:
Delete the TAPS.aef script and the TAPS application from the IP Contact Center (IPCC) server. You need to uninstall TAPS through Add/Remove Programs. Then, reboot the server.
Re-install the TAPS plug-in. After installation, choose Applications > AAR Management in CRS Administration, and upload the TAPS AAR.aar file. After the TAPS.aar file is uploaded, an application called TAPS is created, and the TAPS.aef script uploads.
Restart the CRS Node Manager from Microsoft Windows services.
Browse to C:\TAPS\.
Open the TAPS application from the Application Management page.
Choose TAPS.aef from the Script* menu.
Click Update.
I didn't have to uninstall the TAPS plugin.
In CRS, go to Applications -> AAR Management
Browse for the TAPS script file (C:\TAPS)
Upload file
You should now see the script in Script Management and should be able to select it in Application Management.
Resstart Node Manager
Good luck, hope this helps.
Martin
jessakhanian Tue, 08/25/2009 - 13:34
Does anyone know if restarting the Node Manager on the CRS server will cause any issues with call-processing on that server? Will the agents still be working fine, or will this be disruptive?
Joseph
