Some VLAN help
Oct 18th, 2007
I used this documentation to setup my WLC in a lab for testing.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805e7a24.shtml
Vlan 1 = 10.5.32.1 255.255.248.0
Vlan 200 = 10.5.40.1 255.255.248.0
I have two vlans 1 and 200. I created a vlan 200 interface just like in the documentation on the WLC. The ap is plugged into a port on vlan 200 and can associate with the WLC (and grab a dhcp address) from a dhcp server which is on VLAN 10.
I have no secuirty set up on the wireless ap as im just playing around with things. I can ping the wireless interface i made on the WLC from the WLC but i cant ping it from any other device. Is that normal? Reading the documentation it sounds like i should be able to ping the wireless interface from any device on the network (i cant ping the wireless interface from the ap either)
Also i think this is cause the problem where the laptop tries to associate with the ap it cant get an ip address.
I have a 3560 running a layer 3 IOS for this lab. With the WLC on a port that allows multiple vlans do i need to setup a static route of some sort to allow communication? Or maybe im just in over my head lol
Any information you need dont hesitate to ask! Thanks!!!
sullyjman Fri, 10/19/2007 - 04:25
Okay so i left work yesterday, we had a power outage and came back in this morning and it now works.
I only have one AP on the network for testing and i noticed that while that AP is off, i cant ping the wireless interface. (is this correct) This is so weird, i have been fighting this all week and now it works.
