VPN
Cisco CyberSecurity
Labels
Hello, Is it possible on Cisco FTD managed by Cisco FMC define multiple DH Group in Phase2 ? From what i see it is just possible one. I tried put , but it doesnt accept. Also looking maybe for option to add thorugh flex config but didnt find any rel...
qsscisco by Level 1
  • 298 Views
  • 9 replies
Hello, we're running Cisco Anyconnect 4.2 NAC to connect to our VPN. I'm running into an issue where it's telling me that there are no network adapters. I've tried uninstalling/re-installing the network adapter drivers, Cisco NAC and I just can't get...
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
I have multiple AnyConnect connection profiles for various remote users that provide access to different internal networks. The authentication method needs to be certificate only, but there doesn't seem to be a way to prevent an issued certificate ho...
Crag Muer by Level 1
  • 189 Views
  • 8 replies
  • 1 Helpful votes
Hi! The last weeks it has been a big increase of brute force attempts from all over the world to our Cisco ASAs. We use two factors, so we're not to afraid that they will actually access any of our accounts, but the problem is that they manage to blo...
Sonflaa by Level 1
  • 244 Views
  • 9 replies
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 336 Views
  • 10 replies
As per the CVE, the detailed information is available in the advisory : Cisco Adaptive Security Appliance Software and Firepower Threat Defense Software Remote Access VPN Unauthorized Access Vulnerabilityhttps://sec.cloudapps.cisco.com/security/cente...
Jay Kumar by Cisco Employee
  • 15948 Views
  • 4 replies
Working on VPN and we are getting errors stating no TP found.  Did a sh ssl/ sh run ssl and got weird information back but need help with understanding TP's
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 774 Views
  • 31 replies
