MOH
Answered Question
Is there a way to import multiple music files and have the MOH play them like a play list.
What we want to do, is import 5 - 10 songs and have them cycle through playing continuously.
We don't want just one song playing all the time. Also, when a person gets put on hold can the music just start from where it is playing (so the person doesn't always here the same song starting?)
Correct Answer by Rob Huffman about 9 years 4 months ago
Hi Steve,
Format:
Average Data Rate 8.0 kb/second
Sample Rate 8.0 Khz
Audi Sample Size 8.0 Bit
Channels 1 (Mono)
Here is how to change the MOH for CallManager;
Music On Hold Audio Sources
An MOH audio translator service converts administrator-supplied audio sources to the proper format for the music on hold server to use. The audio translator uses two parameters, an input directory and an output directory. You can configure the input directory, which defaults to C:\Program Files\Cisco\MOH\DropMOHAudioSourceFilesHere, on a per-service basis. The output directory, a clusterwide parameter, contains a Universal Naming Convention (UNC) name to a shared directory on the default MOH TFTP directory. For whatever directory is specified, append \MOH.
When the administrator drops an audio source file into the input directory, the MOH Audio Translator processes the file and then moves it into the output directory along with any files that are generated. Cisco CallManager supports most audio source file formats as input sources, including wav and mp3 files. After the input audio source is converted, an audio source file exists for each codec type that the music on hold server supports. Supply the highest quality source that is available.
From this good MOH doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a9f.html#wp1027441
Also,here is a great answer from Jorge that explains things perfectly;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddbd2c3/0#selected_message
Hope this helps!
Rob
Overall Rating: 3.7 (3 ratings)
Paolo Bevilacqua Tue, 10/23/2007 - 09:07
You need special software to properly convert mp3 to audio files usable for telephony.
Cooledit is one of them, you need to activate the conversion from a menu, not just 'save as'.
hope this helps, please rate post if it does!
Correct Answer
Rob Huffman Wed, 10/24/2007 - 08:00
Hi Steve,
Format:
Sample Rate 8.0 Khz
Channels 1 (Mono)
Hope this helps!
Rob
Thanks everyone, but I think I have not explained the problem clearly.
I have following the normal steps for converting the files, as stated in the above link.
The problem is once that file has been converted, when I play it back as MOH on a phone, there is a lot of scratching sounds, static, that was not present in the orginial mp3 format.
I am not sure why it is doing this!
