CCVP Lab - PSTN Simulator?
Oct 18th, 2007
All,
I am working with a partner on creating a CCVP/CCIE Voice lab to pursue those certifications. We have most of the pieces already in place (voice gateways, routers, switches, CME, CallManager, etc) but I did have one question about setting up a PSTN simulator using a Cisco router. I'm somewhat confused on how best to emulate this technology in a lab environment to help me adequately prepare for those certifications.
http://www.certificationtalk.com:81/showflat.php?Cat=&Board=VGen&Number=29921&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1
That link discusses a config (at the bottom of the page) that will emulate a PSTN connection by basically turning a router into an H.323 gateway (if I understand it correctly, correct me if I'm wrong).
Another link (http://corner-il.blogspot.com/) has instructions for setting up a PSTN emulator using Dynamips running a 2691 image and this config:
Relevant sections of the PSTN router
frame-relay switching
interface FastEthernet0/1
ip address 10.100.1.1 255.255.255.0
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.100.1.1
interface Serial1/0
description HQ-RTR
no ip address
encapsulation frame-relay IETF
serial restart-delay 0
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 201 interface Serial1/1 101
frame-relay route 202 interface Serial1/2 102
interface Serial1/1
description BR1-RTR
no ip address
no fair-queue
frame-relay route 101 interface Serial1/0 201
interface Serial1/2
description BR2-RTR
no ip address
frame-relay route 102 interface Serial1/0 202
ip route 10.11.1.0 255.255.255.0 10.100.1.2
ip route 10.12.1.0 255.255.255.0 10.100.1.3
ip route 10.13.1.0 255.255.255.0 10.100.1.4
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
dial-peer voice 2000 voip
destination-pattern 1011111...
session target ipv4:10.11.1.254
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 3000 voip
destination-pattern 2022222...
session target ipv4:10.12.1.254
codec g711ulaw
no vad
dial-peer voice 4000 voip
destination-pattern 3033333...
session target ipv4:10.13.1.254
codec g711ulaw
no vad
dial-peer voice 1 voip
incoming called-number .
codec g711ulaw
no vad
telephony-service
load 7960-7940 P00307020200
max-ephones 1
max-dn 5
ip source-address 10.100.1.1 port 2000
ephone-dn 1 dual-line
number 911
ephone-dn 2 dual-line
number 1015551111
ephone-dn 3 dual-line
number 2025552222
ephone-dn 4 dual-line
number 3035553333
ephone-dn 5 dual-line
number 55987654321
ephone 1
mac-address 0000.0000.0000
type 7960
button 1:1 2:2 3:3 4:4 5:5
gateway
END CONFIG
Will this be adequate enough for our labbing purposes or should we look at getting an ADTRAN to simulate the PSTN? Thanks!
Overall Rating: 3 (4 ratings)
UCcomp2007 Sun, 10/21/2007 - 16:08
I asked the same question a while back and got some good advice. I have three voice gateways. Gateway one and Gateway two are connected to CM environment. Each of those has a T1 interface. Each T1 is setup to get clocking from the line. Under Serial 0/0:23 I added line ISDN Protocol-emulate USER
Then I have a seperate Gateway with two T1 interfaces, running CME (not part of CM environment). I configured this CME routers T1's to be the Network side (ISDN Protocol-emulate Network) and provided the clocking to the other gateways. I use this CME gateway to act as a PSTN node. You will need a T1 back to back cable to connect the T1's together.
adandrade Thu, 11/29/2007 - 14:51
You could get a PCI 4-T1 card (350USD) and a cheap P3 PC with at least 256M and install and configure ASTERISK and you are done.
Advantages
1.- Get a PSTN Simulator (T1 or E1) for 450 USD
2.- You get to learn some useful ASTERISK skills.
ccbootcamp Fri, 11/30/2007 - 09:43
We use a 2811 (CME) w/ PVDM2s, VWIC-2MFT-T1, VWIC-2MFT-E1, NM-4A/S (for frame-relay). Make sure you have the correct files on the flash as well to handle CME:
(yes, there are some extra files you wont need for your PSTN sim, I just have all the CME files on the flash)
PSTN Router Show flash:
PSTN-WAN#sh fla
-#- --length-- -----date/time------ path
1 491213 Mar 29 2007 18:23:26 -07:00 128MB.sdf (NOT NEEDED FOR VoIP, just for IPS)
2 4308 Aug 30 2005 15:56:58 -07:00 admin_user.html
3 642871 Aug 30 2005 15:57:00 -07:00 admin_user.js
4 16369 Oct 12 2005 11:01:18 -07:00 app-b-acd-2.1.0.0.ReadMe
5 24679 Oct 12 2005 11:01:18 -07:00 app-b-acd-2.1.0.0.tcl
6 33870 Oct 12 2005 11:01:32 -07:00 app-b-acd-aa-2.1.0.0.tcl
7 281506 Jul 29 2004 12:54:12 -07:00 ATA030100SCCP040211A.zup
8 34023596 Jul 17 2007 19:49:38 -07:00 c2800nm-adventerprisek9_ivs-mz.124-3g.bin
9 1602 Aug 30 2005 15:57:00 -07:00 CiscoLogo.gif
10 638 Sep 16 2005 15:12:40 -07:00 CME_GUI_README.TXT
11 331101 Feb 08 2005 14:26:46 -08:00 CP7902060000SCCP050124A.sbin
12 338897 Feb 08 2005 14:26:46 -08:00 CP7905060000SCCP050124A.sbin
13 338481 Feb 08 2005 14:26:46 -08:00 CP7905060000SCCP050124A.zup
14 340247 Feb 08 2005 14:26:46 -08:00 CP7912060000SCCP050124A.sbin
15 953 Aug 30 2005 15:57:00 -07:00 Delete.gif
16 16344 Aug 30 2005 15:57:00 -07:00 DOM.JS
17 864 Aug 30 2005 15:57:00 -07:00 downarrow.gif
18 75650 Oct 26 2004 12:27:28 -07:00 en_bacd_allagentsbusy.au
19 83291 Oct 26 2004 12:27:28 -07:00 en_bacd_disconnect.au
20 63055 Oct 26 2004 12:27:28 -07:00 en_bacd_enter_dest.au
21 37952 Oct 26 2004 12:27:28 -07:00 en_bacd_invalidoption.au
22 496521 Dec 17 2001 12:16:28 -08:00 en_bacd_music_on_hold.au
23 123446 Oct 26 2004 12:27:28 -07:00 en_bacd_options_menu.au
24 42978 Mar 31 2005 11:17:40 -08:00 en_bacd_welcome.au
25 6146 Aug 30 2005 15:57:00 -07:00 ephone_admin.html
26 4658 Aug 30 2005 15:57:00 -07:00 LOGOHOME.GIF
27 496521 Mar 29 2004 13:40:48 -08:00 music-on-hold.au
28 3724 Aug 30 2005 15:57:00 -07:00 normal_user.html
29 77200 Sep 16 2005 15:12:04 -07:00 normal_user.js
30 128792 May 09 2005 19:32:24 -07:00 P00307020200.bin
31 458 May 09 2005 19:32:36 -07:00 P00307020200.loads
32 680394 May 09 2005 19:32:32 -07:00 P00307020200.sb2
33 129196 May 09 2005 19:32:28 -07:00 P00307020200.sbn
34 333822 Jul 29 2004 12:53:46 -07:00 P00403020214.bin
35 1908762 Aug 04 2004 15:43:46 -07:00 P00503010100.bin
36 1347 Aug 30 2005 15:57:00 -07:00 Plus.gif
37 47904 Jul 29 2004 12:53:46 -07:00 S00103020002.bin
38 49169 Sep 08 2004 18:35:46 -07:00 S00104000100.sbn
39 843 Aug 30 2005 15:57:00 -07:00 SXICONAD.GIF
40 174 Aug 30 2005 15:57:00 -07:00 Tab.gif
41 2392 Nov 10 2005 13:44:34 -08:00 telephony_service.html
42 870 Aug 30 2005 15:57:00 -07:00 UPARROW.GIF
43 3311 Aug 30 2005 15:57:00 -07:00 xml.template
44 9968 Aug 30 2005 15:57:00 -07:00 xml-test.html
PSTN config:
http://www.ccbootcamp.com/download/Voice/Files-For-NLIs-CCIE-Voice-Lab-Workbook/base-configs/PSTN-v3.txt
-brad
(please rate the post)
