Router on a stick and NAT.
Answered Question
Oct 18th, 2007
I have 2 vlans, 1 private and 1 public on a 1924 switch, trunk B is attached to f0/0 on a 2621 and packets are routed via sub-ifs. I was initially using some SOHOs to connect the Internet and my two vlans together with links between each vlan group to the sohos and the sohos to each other. (See attached diagram)
I would like to move this 2 router setup to just 1 router. I've tried what I thought was going to be a simple setup and it has yet to work 100%. Is what I want to do possible with just a 2621? Or will I need to add an wic-1enet, get rid of the trunking and just link 1 ethernet port to each vlan?
What I've found out so far -
Using the config below, hosts on my private lan (vlan42) are able to ping and access each other, their gateway (f0/0.42), f0/0.191, & di1. Host's on my private lan (vlan42) can not get past di1 to get on to the Internet. Hosts on vlan191 can get onto the Internet ok, and the Internet to them.
When I ssh from a host on vlan42 to a host on vlan191 nat appears to work. The vlan191 host tells me I'm coming from my inside global address (f0/0.191) IP address. But from hosts on vlan191 I can ping hosts directly on vlan42 (192.168.42.x), nat doesn't appear to be working in this direction.
c1924 (cs1-iwc)
+e0 - e7
+ vlan191 (Public IPs)
+e17 - e24
+ vlan42 (Private IPs)
+Trunk B - Cabled to c2621 f0/0
+ Allowed vlans 1, 42, 191
c2621 (cr1-iwc)
+f0/0 (Trunked link to 1924)
+f0/0.42 (nat inside)
+ip 192.168.42.33/28
+f0/0.191 (nat outside)
+ip x.x.191.33/28
+f0/1 - Hooked to DSL Modem
+di1 - pppoe setup
c2621 setup:
cr1-iwc#sh run
Building configuration...
Current configuration : 5468 bytes
version 12.3
service timestamps debug datetime localtime
service timestamps log datetime msec localtime show-timezone
hostname cr1-iwc
boot-start-marker
boot-end-marker
memory-size iomem 15
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
ip tcp path-mtu-discovery
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.42
encapsulation isl 42
ip address 192.168.42.33 255.255.255.240
no ip redirects
ip nat inside
no snmp trap link-status
interface FastEthernet0/0.191
encapsulation isl 191
ip address x.x.191.33 255.255.255.240
no ip redirects
ip nat outside
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
description PPPoE Connection
ip address negotiated
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username x
ip nat inside source list NAT interface FastEthernet0/0.191 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard NAT
permit 192.168.42.32 0.0.0.15
dial-peer cor custom
end
Thanks for any insight that anyone can offer.
-Sean
Correct Answer by sundar.palaniappan about 9 years 9 months ago
Sean,
Can you make the following changes and try.
Add:
interface Dialer1
ip nat outside
ip access-list ext NAT
permit ip 192.168.42.32 0.0.0.15 any
Remove:
no ip access-list standard NAT
Sundar
Overall Rating: 4 (1 ratings)
Correct Answer
sundar.palaniappan Thu, 10/18/2007 - 15:32
  • Green, 3000 points or more
Sean,
Add:
interface Dialer1
ip nat outside
Remove:
Sundar
sean.crites Mon, 10/22/2007 - 13:02
Thanks Sundar, that fixed the problem I was having!
-Sean
